Configure OVSDB Replication
Use the following procedure to configure OVSDB replication to support vIST.
  • You must enable VXLAN Gateway Full Interworking Mode on the switch.
  • You must configure an OVSDB managed interface on the switch.
  • You must configure and enable OVSDB protocol support for VXLAN Gateway on the switch.
  • You must have at least two NVCs configured to communicate on the managed interface network.
  1. Enter OVSDB Configuration mode:
    enable
    configure terminal
    ovsdb
  2. Configure the OVSDB replication:
    replication peer-ip <A.B.C.D> local-ip <A.B.C.D>
The following is an example configuring OVSDB replication to support VIST.
SWITCH:1>enable
SWITCH:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
SWITCH:1(config)#ovsdb
SWITCH:1(config-ovsdb)#replication peer-ip 192.0.2.3 local-ip 192.0.2.2
Variable definitions
Use the data in the following table to use the replication command.
Variable
Value
peer-ip <A.B.C.D>
Specifies the IP address of the secondary controller for OVSDB replication support.
local-ip <A.B.C.D>
Specifies the IP address of the primary controller for OVSDB replication support.
